Will I have enough Power to upgrade my graphics card?
DonkeyFlem5
15
Hey guys i'm upgrading my card from a 760 (2gb) to a 970 (4gb). I'm worried that I would not have enough power to run it and if I did would I be able to add a extra 8gb (RAM). 600w corsair power supply
Processor Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz
Manufacturer Intel
Speed 3.4 GHz
Number of Cores 4
Video Card NVIDIA GeForce GTX 760
Manufacturer NVIDIA
Chipset GeForce GTX 760
Dedicated Memory 2048 MB
Total Memory 4.0 GB
Memory 8.1 GB
Operating System Microsoft Windows 10 (build 10240), 64-bit
Service Pack 0
Size 64 Bit
Edition
Display Maximum Resolution 1920 x 1080
DVD HL-DT-ST DVDRAM GH24NSB0
CD HL-DT-ST DVDRAM GH24NSB0
Drive
Size 1.8 TB
Maybe I missed it but you have everything listed but the one item that will tell us if your system can handle the new card, the power supply. If it's a good quality 500w or better you should be okay.
The 900 series has pretty good power management and draws a relatively low amount of wattage. If you are currently running a 760, chances are you should be fine to upgrade both your GPU to a 970 along with upgrade the RAM to 8GB.
Would help to know what PSU you have though.
