Yes, assuming the total space occupied on the hard drive is less than the capacity of the SSD. Most of the nicer SSDs, like Samsung's, come with a cloning utility, or access to a one-way cloning tool for use with their devices only.
If this was me, I'd just reinstall it. Most likely faster and less of a hassle than migrating between drives.
To answer your second question:
If you have a retail key: You will not need a new Windows key.
If you have an OEM key: You will not need a new Windows key, OEM keys bind to the motherboard.
If you upgraded to Windows 10: You will not need a new Windows key, it will be activated automatically when you install Windows.
