[SOLVED] Will LG 34WK95U Use a lot of GPU Power?
Sep 7, 2020
37
Hello guys,
I'm gonna be buying a 3090 or a 3080, or maybe even a 6900XT
and for CPU it is gonna be a 5950x
I'm gonna be doing 3d rendering, Simulations, Animation and NO GAMING....
So if I'm buying either the 34WK95-U Monitor or the 32UL950 or the 32UD99
will those monitors use my GPU a lot and slow me down while there is a work-load ??
cause there are a lot of pixels the GPU need to drive and while I'm simulating or rendering stuffs....It's gonna be Intensive, so.....Does having a 4k or 5k2k monitor affect my render times or slow me down while I'm simulating stuffs ??
Hello guys,
The short answer, nope not at all. Your GPU is displaying an almost entirely static image and has almost nothing to...
Hello guys,
The short answer, nope not at all. Your GPU is displaying an almost entirely static image and has almost nothing to render.
I can speak from personal experience (I have a 4k monitor and run folding@home calculations on two GPUs 24/7) that the resolution of your monitor will have a negligible affect on your render performance. Choose the monitor that suits you best.
Thanks a lot for confirming, I'm opting for 34WK95-U
Reactions: RTX 2080
