Question Will msi b450 mortar max fits into my case?
simo311
56
I'm going to replace my motherboard with the msi b450 mortar max, but i want to be sure that it will fits into my pc case.
From what I know, my case only support matx motherboard.
Is the msi b450 mortar Max a mATX motherboard? I currently have the msi b450 gaming plus and it's actually a bit shorter than it should be.
P. S. Will the msi b450 mortar max support amd Ryzen 3000 series natively? Or I will have to update the bios in order to use my Ryzen 5 3600?
Thanks!
yes. it is a mATX board
yes there are only two BIOS revisions and the oldest supports some 3000 series chips, the 3600 is one of those supported. a BIOS update is required for newer chips though like the ryzen 3950x and the 3500x.
https://www.msi.com/Motherboard/support/B450M-MORTAR-MAX#support-cpu
OK, great.
Will the msi b450 mortar max be 100% compatible with all my other components?
My other pc components :
System:Windows 10(64 bit )
CPU:AMD Ryzen 5 3600
Memory: Viper 4 2x8 DDR4 3200MHz
Disk: ADATA SX900 ATA Device 64 GB SDD + Toshiba DT01ACA200 ATA Device 2000 GB HDD + SAMSUNG HD502HI ATA Device 500 GB HDD
Display adapter:NVIDIA GeForce GTX 780(3.00 GB)
Motherboard:
Monitor: Samsung c24f390 24" LED Curved Monitor
Thanks!
