[SOLVED] will my 700w power supply be enough for my build?
Your system could probably run on a 550W.
A 650W would be more than enough with headroom.
PCPartPicker Part List
Power Supply: Corsair RMx (2018) 650 W 80+ Gold Certified Fully Modular ATX Power Supply ($119.98 @ Newegg)
Total: $119.98
Power Supply: EVGA SuperNOVA G3 650 W 80+ Gold Certified Fully Modular ATX Power Supply ($85.88 @ OutletPC)
Total: $85.88
Power Supply: Corsair TXM Gold 650 W 80+ Gold Certified Semi-modular ATX Power Supply ($102.98 @ Newegg)
Total: $102.98
Power Supply: SeaSonic FOCUS Plus Gold 650 W 80+ Gold Certified Fully Modular ATX Power Supply ($96.95 @ Amazon)
Total: $96.95
Power Supply: EVGA...
Completely agreed with vapour above, quantity is useless without quality.
The RTX 2080 (in most systems) can run on a good quality 600W.
The SMART PSUs are not great, the best one is arguably the PRO version, but even then it's a budget model and there are plenty better.
So will it technically work? - probably yes.
Would it be safer and better to probably upgrade the PSU? also probably yes.
Reactions: King_V
Total: $119.98
Total: $85.88
Total: $102.98
Total: $96.95
Power Supply: EVGA SuperNOVA G1+ 650 W 80+ Gold Certified Fully Modular ATX Power Supply ($85.88 @ OutletPC)
Total: $85.88
Power Supply: SeaSonic FOCUS Gold 650 W 80+ Gold Certified Semi-modular ATX Power Supply ($79.90 @ Amazon)
Total: $79.90
Power Supply: BitFenix Formula Gold 650 W 80+ Gold Certified ATX Power Supply ($75.99 @ SuperBiiz)
Total: $75.99
Then if you want to go cheaper (which means lower quality) but still good quality:
Power Supply:
Corsair CX (2017) 650 W 80+ Bronze Certified ATX Power Supply ($69.88 @ OutletPC)
Total: $69.88
