Will My CPU bottleneck with R7 265
Utkarsh,
You're good, you may even be able to go a tier or two higher down the road without changing CPU but that would be the last GPU you should pair with that CPU.
Like I said in the first post, the card isn't going to give you very high FPS that would cause CPU bottlenecking. At 1366x768, you'll probably be limited by your monitor's refresh rate more than anything else in your system, so go ahead and try high settings, should work just fine.
Not Expecting High Fps as i know i would need a better Gaming Pc and also my ram is 4gb which is going to limit my settings too.
