[SOLVED] Will my FSP Hyper S 700W PSU able to run the RTX 3080 VGA card?
Sep 5, 2020
6
My setup is an i7 6700k CPU , motherboard asus z170 pro gaming , nhd15 cpu cooler , 32 gb ram corsair vengeance , nzxt phantom 410 case and the psu is Hyper S 700W .
Will this PSU able to run a RTX 3080 VGA card?
Thanks in advance!
Thanks in advance!
The +12volt output for the FSP Hyper S 700W is 636 watts and the build quality is only mediocre at best. I recommend replacing it if you want to buy a RTX 3080.
How old is the PSU you're working with now? Considering a PSU will degrade over time once you bring overclocking into the picture, meaning that the PSU is likely outputting far less than what the unit did while it was brand new.
Also, wait a little to see what the reviews have to say about the power draw of the card. Some people who fabricate cables/sleeving are already having a tough time figuring out the connector for the proprietary connector. In fact, it's not even made by Molex(the brand, not the 4pin plug).
There's also the matter of the card being just announced, you should wait to see reviews of the card before making a decision to buy it.
Thanks in advance!
