Will my i7 2600k running at stock speeds bottleneck a GTX 1080?
redness
144
I'm too scared to overclock because I live in a very hot area and I don't want my PC to explode. Please don't make fun of me.
Yes.
Here's an example from Doom:
Notice how all the i7's going back to the 3770k [the 2600k wasn't benchmarked, but likely performs the same] cap out at about 140 FPS? That's a GPU bottleneck; the GPU simply can't render frames any faster, even though the CPU can. So you can guesitmate, based on 3770k/2500k performance levels, that a 2600k could push at least 140 FPS in DOOM, and likely more.
Point being, pretty much every game benchmark review shows that Intel i7 CPUs...
While I understand what you mean, I also live at tropical weather, anything you did on your PC won't make it broke. The Sandy Bridge platform had enough fail-safe mechanism to protect CPU from damage. Unless you somehow disable it. The motherboards however, has none. So the chances are, if anything broke, it would be motherboard.
To answer your question, yes your CPU will bottleneck it. However, no so much so that the 1080 will gets outperfomed by at least 2 tiers below it. Even with far better CPU.
Not sure what you mean. More pixels = more GPU load, doing this you're likely to run into a GPU bottleneck first.
2600K will bottleneck any video card sometimes, but in a vast majority of games it won't matter, because your framerate will still be plenty high.
Regarding overclocking, I wouldn't worry. Intel CPUs are notoriously hard to kill.
I do have one. I have a 212x evo. You think I'll be safe to overclock now?
As for my ambient room temperature. I dunno. It's hot enough that my dog wants to get out of my room because it's hot.
Oh nooooooo. I thought it would be fine 🙁
Most people don't have a clear understanding of how CPU and GPU bottlenecks work, it seems. In simple terms:
In a given scene, there will be a certain amount of CPU power need for a given framerate. I'll make up some numbers - your CPU may be able to deliver 90fps at stock clocks in a particular scene in a game. If you drop in a GTX 1080, at low settings, it may be able to deliver 200fps, so your CPU will be bottlenecking you at 90fps. However, if you crank up the graphical settings, the CPU will still be able to deliver 90fps, but the GPU may only deliver 50fps, so you're now "GPU bottlenecked". One is always bottlenecking the other, or you'd have infinite frames per second.
The amount of CPU and GPU power needed is contantly varying. The goal is to have enough of either to have the framerates you want, at the graphical settings you want. However, you can always reduce GPU load by lowering graphics, but you can't do anything about it if your CPU is limiting you to a framerate that's less than you want, other than overclock or replace the chip.
Any CPU will bottleneck any GPU sometimes, but it probably won't matter, because a 2600K will still deliver an excellent experience in the vast majority of games.
Even at stock speed?
I would imagine so, yes. In cases where it DOES bottleneck, you can increase your framerates with an overclock. It just depends on what your expectations are, and what game you're playing.
Yes.
Point being, pretty much every game benchmark review shows that Intel i7 CPUs are not CPU bottlenecked, going back to the 2000 series. You might lose a handful of FPS compared to a newer architecture, but no more then that.
Thank you for the very helpful posts! I am now excited to get my GTX 1080 and play Doom at 60FPS!
It is sad I can only choose one best answer since you all have been helpful so thank you again!
