I will be getting a NZXT Phantom 410 mid-tower case. I also plan to get a XSPC AX240 dual 120mm radiator. Will I be able to fit this radiator in my case in a pull configuration. Also where would I mount the reservoir, would it fit in the front if I removed two 5.25" drive bays and had an optical drive in there too?
Here is a link to the case and the radiator:
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811146093&ignorebbr=1
Radiator: http://www.frozencpu.com/products/17141/ex-rad-440/XSPC_AX240_Dual_120mm_Radiator_w_Aluminum_Enclosure_-_Black.html
