Will Nintendo Switch Look Horrible Outputting to 1440p monitor
test_123
96
I was thinking about jacking my Nintendo Switch Dock to a 1440p monitor when I can finally find a Switch. The Switch tops out at 1080p. Do you think it'll still look ok?
This depends on the monitors rescale function. At my 1440p monitor setting any game to 1080p resolution makes it a bit blurry. That is because of the monitors scaling feature does not show pixel perfect image. I don't know your monitor. You can test it, just play a pc game at 1440p native resolution and then set it to 1080p and compare. If it looks acceptable, then this will be the same with the Switch (I suppose).
I have an ASUS 1440P monitor and I just plugged BOTW into it and it looked horrible. When I play 1080P games on my PC they don't look nearly as bad, definitely a difference between 1080p and 1440P but I'm the only one in my house that can even notice it. I think maybe a TV would be better, I've seen videos of BOTW on a 4K TV and it looked just fine.
Wow! I guess I won't know until I see for myself. BTW, I'm 3/4 through the game and it's amazing.
