Will Noctua NH-D14 fit Antec P183 v3 case?
michtech
4
I am planning to build a new system and was wondering if anyone knows if the NH-D14 will fit in an Antec P183 v3 case?
The motherboard will be ASUS z87 Maximus VI Hero and cpu is i5 4670.
I have checked the compatibility chart on Noctua and the motherboard is compatible.
The heatsink is 160mm in height (including fan) and the case width is 205mm.
Thanks
Thanks nukemaster for the quick reply.
The cooler height is 160mm and width is 140mm, depth is 158mm.
Do you mean I need to check the space between behind botherboard to the other side of the case?
I saw the same thread on SPCR too, I'm assuming that photo posted is of the NH-D14 and the case is also the Antec P183 (the one I'm using is P183 v3, but hopefully has same internal dimensions, Antec only shows external case dimensions)
