L Lachieman Reputable Aug 22, 2014 8 0 4,510 Oct 28, 2015 #1 Was wondering if the noctua nh-d14 will fit in my GT1 Inwin White case on a MSI 970 Gaming Mbo with 2x4gb of kingston hyperx black memory. Thanks
Solution RCFProd Oct 28, 2015 Maximum CPU Heatsink up to 160mm (From CPU Die Surface to Side Panel) Noctua NH-D14 height = 160mm This means it won't fit. A CPU Cooler on or below 150mm is recommended.
RCFProd Expert Ambassador Dec 8, 2013 12,605 29 56,990 Oct 28, 2015 Solution #2 Maximum CPU Heatsink up to 160mm (From CPU Die Surface to Side Panel) Noctua NH-D14 height = 160mm This means it won't fit. A CPU Cooler on or below 150mm is recommended. Upvote 0 Downvote Solution
