could you be more specific how do i do that![]()
You would have to rewire the pinouts... or buy an adapter like this.
Dell 5 pin to 4 pin Fan Connector Adapter $1.5
I'm assuming you have the original 5 pin fan and a 4 pin PMW replacement.could you be more specific how do i do that
Btw thanks for the answer
Sadly, i don't have 5 pin fan. what about if i just change places of the cables on 4 pin.And my cooler is a little bit old and has different cable colors like this View: https://imgur.com/llgwCnQI'm assuming you have the original 5 pin fan and a 4 pin PMW replacement.
You will need a small screwdriver, needle or stick pin to do this. I suggest this because I have done it several times over the years myself. 😊
- Remove the pin tabs from the 5 pin fan connector.
- Remove the pin tabs from the 4 pin connector.
- Push the pin tabs from the 4 pin PWM fan into the 5 pin connector in the order above.
Mounting hole spacing can be an issue as well and sometimes you have to get friendly with a Dremel to make things work.
