[SOLVED] Will the case Cables work with the motherboard?
thekillerx10
538
38
10,990
im gonna build my first pc
Iam gonna build a ddr3 build cuz i can't afford a ddr4 one
i will buy the cougar mx 330 case and asus h61M-LE R2.0 motherboard
i wanted to know if the cables of the case will get connected to the ddr3 motherboard
cuz i have seen all that are making a build with this case doing a ddr4 build so i don't know if works on a ddr3
Yea that is the motherboard
and the build specification are:
Processor : i5 3470
Gpu :Gtx 1650
Ram : any 8gb (2x4) 1600 mhz ddr3
Case : cougar mx 330 + 500 wat psu the power supply comes with the case
There will be cables from the "case" (PSU, switches, LED's etc.) to the motherboard.
That will be true independent of what that motherboard supports with respect to DDR3 orDDR4.
Does the following link show the motherboard you have in mind?
https://www.asus.com/Motherboards/P8H61M_LE_R20/specifications/
And your plan is to use some PCIe adapter to host the DDR4 RAM modules?
It is the motherboard that determines what components are supported and in what combinations.
For the most part that information is presented in both the motherboard's specifications and/or the User Guide/Manual for installing the motherboard.
Please explain more about your build and the components you are intending to use.
Processor : i5 3470
Gpu :Gtx 1650
well i did some researches and found that this motherboad is better asus P8Q77-M cause it have sata 3,usb 3 and i can connect 1 additional fan but i wanted to ask u does the case fan should be connected to the motherboard and if it does, does this case stock fan (cougar mx 330) comes with a 3 pin or 4 pin fan cause this motherboard comes with only 2, 3 pin fans
