Z zDewey Commendable Nov 26, 2016 7 0 1,510 Nov 26, 2016 #1 Hi everyone, As thevtiyle says, will it fit my Thermaltake Commander MS-ll?
Solution Dark Lord of Tech Nov 26, 2016 No it won't , your case supports up to 155mm , the EVO is 159mm.
Nerdy Nerd Reputable Mar 19, 2016 814 0 5,360 Nov 26, 2016 #2 You know who should be on your friend list? This: www.pcpartpicker.com Upvote -1 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,615 1,779 159,590 Nov 26, 2016 Solution #3 No it won't , your case supports up to 155mm , the EVO is 159mm. Upvote 0 Downvote Solution
Nerdy Nerd Reputable Mar 19, 2016 814 0 5,360 Nov 26, 2016 #4 Yep pcpartpicker would have detected that. XD. So blackbird is right. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,615 1,779 159,590 Nov 26, 2016 #5 partpicker has been known to be wrong , always best to look it up on the sites. Upvote 0 Downvote
Z zDewey Commendable Nov 26, 2016 7 0 1,510 Nov 26, 2016 #6 Thanks everyone. As I tried to use the site that was given. It seems that I cannot find my case there. So it wasn't really helpful. Thanks though. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,615 1,779 159,590 Nov 26, 2016 #7 CPU cooler height limitation: 155mm VGA length limitation: 320mm http://www.thermaltake.com/products-model_Specification.aspx?id=C_00001851 Info is here. Upvote 0 Downvote
Nerdy Nerd Reputable Mar 19, 2016 814 0 5,360 Nov 26, 2016 #8 Well, I did not know partpicker for being wrong...it is probably rare though. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,615 1,779 159,590 Nov 26, 2016 #9 It does happen more than you would think , I never put 100% trust in their cooler notifications. Everything else is decent. Upvote 0 Downvote
Nerdy Nerd Reputable Mar 19, 2016 814 0 5,360 Nov 26, 2016 #10 Oh ok, thanks for the new information. Upvote 0 Downvote
