Will the corsair H100i fit in my case???
CrazymanWO
310
Hey guys so i have a mid tower case right now with the h80 water cooler. I am unsure if the h100i will fit in my case. I have 2 fans on top of the case but with the current fans and the ram in the way there is no more room on the top of the case and i am unsure how thin the rad is with the h100i, do you guys think it will fit. The case is a bit old so i cant find the specs of it online.
The name fo the case is AZZA Solaris Gaming Case
It was an ibuypower PC, i got it as a gift, it was complete shit so i gutted the comp, kept the case and just replaced the internals. I cant find any specs of the case online so im unsure its dimensions.
This is the pic of my case. The dimensions and Bays of the case are in the decription.
http://www.amazon.com/iBuyPower-Gamer-Power-AM522D3-Desktop/dp/B006O5ZJJ2
My RIG:
AMD fx 8350 Oced to 4.7ghz
gigabyte 990-fx-ud3
8gb vengence ram
2X EVGA gtx 670 FTW SLI (oced 50mhz)
120gb SSD
1TB HDD
750 watt EVGA PSU
Windoes 8
8 case fans
i would suggest getting a bigger case since u already have a fan on the top and a water cooling system.u might be able to fit it in but it will be very stuffy.
Do you have any full tower case suggestions that are under 100 dollars, I want a case with a good amount of fan ports cause right now my case has 7 fans.
u could try this http://www.newegg.com/Product/Product.aspx?Item=N82E16811156284 cant really say if its any larger than ur case since i cant seem t find the exact dimension of your case.
Well my case is mid tower so any full tower i think would be a bit biger.
Does this one seem fine, seems like this one is really popular.
http://www.amazon.com/NZXT-PHANTOM-Tower-White-PHAN-001WT/dp/B003WE9WQO/ref=sr_1_2?s=pc&ie=UTF8&qid=1378993798&sr=1-2&keywords=full+tower+case
yep.it will do far better than ur old case.its a new case if i am not mistaken.go for it.
Latest posts
