Will the i7 3770 work with RAM clocked at 2133mhz?
The i7 3770 + Asrock Z77 Extreme6 will run your 2133MHz memory just fine.
It'll work just fine, albeit unnecessary. 1600 is plenty and you would never notice ANY difference in everyday usage and gaming between 1600 and 2133.
If you're shooting for high benchmark scores, go right ahead. It's a waste otherwise.
+1 ^
If you're planning to buy new memory, I too would recommend 1600MHz & save some bucks. :)
Yes
From the product page on Newegg
DDR3 2800+(OC)/2400(OC)/2133(OC)/1866(OC)/ 1600/1333/1066
+1 ^
Check this.
