Question Will the NH-D15 fit my case and motherboard
Bubbamaldo
Parts list here. I am currently using the stock cooler and wanted to upgrade to the Noctua NH-D15 . I know there will be very little clearance with the case, the case and cooler both say around 165mm , but I am also concerned with the "block" for lack of a better word near the i/o. Is there any other way to check for clearance. I also believe that the ram will be fine.
CPU Cooler: Up to 165mm
https://www.nzxt.com/products/h500-overwatch
CPU Cooler Height 165 mm
https://www.newegg.com/p/N82E16835608045
It'll be tight, but technically will fit, yes.
HOWEVER that assumes you don't need to raise the front fan to clear your RAM - which is a possibility in some instances. I have LPX and I still had to raise the front fan by a tiny bit - to the point it's slightly above the height of the tower.
It'l be really, really tight.
The D15S might be a better route to go.
https://www.newegg.com/p/N82E16835608072
