Question Will the Noctua NH-D15 CPU cooler fit with these components?
Nov 30, 2019
16
I'm confused if the NH D15 CPU cooler would fit around these components in either of the casings mentioned below. The thermaltake casing has a vertical GPU bracket; is it possible to use that if I put on the NH D15?
Processor: Intel Core i7-9700K 3.6 GHz 8-Core Processor
Motherboard: Gigabyte Z390 AORUS MASTER ATX LGA1151 Motherboard
RAM: CORSAIR DOMINATOR PLATINUM 32GB (2x16)
GPU: Asus ROG Strix GeForce RTX 2080 Ti OC Edition
Casing: NZXT CA-H510I-BR H510i Compact Mid Tower/ Thermaltake View 31
Reactions: RogueNineOne
The NZXT case will accommodate CPU coolers up to 165mm tall:
https://www.nzxt.com/products/h510i-matte-black-red
The TT case, up to 180mm:
https://www.thermaltakeusa.com/view-31-tempered-glass-rgb-edition.html
The Noctua is 165mm tall, with fan:
https://noctua.at/en/nh-d15/specification
The TT should be fine being used with the Noctua. T
NOTE: Corrected after Phaaze88 pointed out correctly that I forgot to include the fan height as well.
Thank you! Really appreciate the time you took to help out.
