These:
https://www.shop4no.com/brackets-fi...orfvd1dx2-18-coysuwsg50sqtf7hygwaapj5ealw_wcb
My NZXT Kraken X73 only comes with enough 6-32 30mm screws for one side with 3x120mm fans, I wish to add another set of 3x120mm fans on the other side for a push pull config in my new Lian Li O11 Dynamic XL build. I found these screws for pretty cheap online and was wondering if they will fit inside the X73 Kraken, or if they will end up puncturing a hole in my radiator. Any input is highly appreciated, thank you all in advance!
