[SOLVED] Will this cooler fit in my case and motherboard?
Feb 14, 2020
76
I got a be quiet dark rock pro 4 and it doesnt fit in my case, will a cooler master hyper 212 evo fit in my case and motherbaord? i have a dell inspirion 3670 with a gtx 1050ti and a m.2 ssd. Thanks
Get a tape measure or ruler.
Measure from the top of the cpu to where the side panel would be if it were on. Then you will know the chassis' available cooler clearance. Convert to mm as needed.
Dark Rock Pro 4: 162.8mm
CM Hyper 212 Evo: 159mm
Your chassis' cpu cooler clearance: ???
