ok my friend built a computer from internet parts through www.pricewatch.com (actually my friend got help from another friend of his who did this, but now that friend who built it for him is in new york). So ANYWAY, he built this computer and had it all set up with win2000. the computer was to the best of my knowledge:
1.4 Athlon w/KT133 Mobo @ 266 FSB
Dual 60GB IBM Deskstar HDs
256MB crucial memory
soundblaster live
matrox video card (i forget the model, its the one that does dual monitor stuff good)
ok so the problem was his computer would freeze alot and so he wanted to format, so he moved his stuff to the other HD (D, and formatted the (C drive with all his root stuff on it. OK here's where problems start.
So win2k doesn't use FAT32, but NTFS, so to format using the old disks with FDISK on it first the HD partitions were deleted and then it was formatted w/FAT16. Then IBM software went to be used and it made it one large partition that could be recognized as 60 rather than 2. Then win2k went to be installed, and it said you could leave it as a FAT hard drive or convert it to NTFS or format it to NTFS, so he chose to format it to NTFS (was that a good move?). Then win2k was installed.
Now everything is up and running, but the problem is the computer acts slow. Example, when playing music off of winamp and surfing the internet, the sound cuts in and out. When playing the windows media player animations full screen it runs choppy. Sometimes the whole computer will slow to a chug for about 20 seconds and the mouse and sound will run really choppy. ITs what you'd expect performance wise from say a Pentium 200 running win2k and stuff, but this is a new top of the line system. Also before formatting this didnt happen.
I tried to help him figure it out and we installed the latest via 4-in-1 drivers and sound card stuff and I checked for background applications but none of that was the problem. Could someone please help? Does anyone know what the problem is or any possible solutions? Could it have anything to do with changing the HD to NTFS?
Thanks for the help!
Danny
soundblaster live
Danny
