Question Wired connection worse than wireless
Sep 19, 2019
5
just had my virgin media upgraded to a bigger package 500 mbps my phone on wireless connection get 200+ mbps but my computer that is connect via Ethernet only gets 5 mbps i've tried different cables and its all the same someone please help.
WildCard999
Herald
my motherboard is Gigabyte B450 Aorus Elite
Are you using Windows 10?
If so is it updated to 1809 or newer?
Did you grab the driver for 1809?
https://www.gigabyte.com/us/Motherboard/B450-AORUS-ELITE-rev-10/support#support-dl-utility
Next thing I'd try is a wireless adapter, if the adapter gives you the correct speed then maybe try contacting Gigabyte as maybe it's an issue with the board.
https://www.gigabyte.com/us/Support
At the very least they may be able to assist you better and if need be can do a RMA.
