Hello
First here is some hardware and software stuff just so you know what I am using currently
OS: Windows 10 pro
Router: Netgear R6400 v2 (Last firmware available from Netgear)
Mobo: ASRock Z97x Fatality
Lan adapter: Killer E2200 (latest drivers available)
ISP provides: 100 megabit optical Internet
Internet installation is as follows
Optical cable --> Optical receiver/modem --> Ethernat cable (1m 1 year old cable) --> Router (Netgear R6400 v2) --> Ethernet cable (6m 2 years old cable) ---> Killer E2200 port
Intro:
Recently I decided to change my stock ISP provided 100 mb/s router, with a Gigabit router. First I got a TP-Link Archer c2 v1 and it was running good for some time until I saw that it disconnects and reconnects for 2-3 seconds about 3-6 times in a row (something like 30 sec in total). During the problem the Light that indicates that there is connection with the computer, is going off and on with the same interval. I tried a few things to fix it like changing ports disabling firewalls and changing other settings with the router. But to no avail.
I returned the router and got myself a better one. The Netgear R6400 v2. And hoped that it will not have the same problem. But after a day, the same problem occurred again. I went absolutely mental since this thing ain't cheap. With the old ISP router I had no such problems but it was only 100 mb/s and I am planning to get gigabit internet later, and on bigger packets and requests it was blocking and throwing me out of some servers which was annoying. And I wanted to fix that and did...
Note: Only wired connection is doing this the WI-Fi is untouched by this problem...
So here is the big story of how I tried everything I could possibly think of to fix the issue:
First I contacted my ISP, Explained in detail what my problem is, and asked them to make my IP static and to try and register the router manually with their servers (if there is such a thing).
It was fine for a day or two. Then it started again. I reinstalled my drivers and network connection and reset the router. and that seemed to have the biggest impact. It was fine for a whole 4 days before occurring again. I tried the same afterwards but for no avail. I had to find a different solution. I contacted Netgear support and they didn't know anything about it.
I reinstalled all drivers, the killer performance suite, the networking connection again and at the same time reset the router to factory default and flash the firmware with the latest version.
And I tried all the easy fixes with changing the ports on the router, turning it off and on again. And basically build from there up in difficulty ...
And recently I found out that instead of local network connection in my network and sharing center it just says Ethernet. And when I open it I have no Ipv6. It wasn't like that about a week ago.
That is when I reset my netsh and netsh Ipv6 reset reset.log from CMD (admin run) and still didn't fix anything.
Some people ask me if my cable is the problem but since I am having no issues with the old router I don't think so. But who knows I might be wrong. (It is a 6 meter 2 years old cable).
Also I noticed that the problem occurs much more often if I am playing a game or getting my network under heavy load. That is when I decided to uninstall my performance suit since it is prioritising some apps like games before others. And I thought that maybe because of that the problem happens. Again to no avail it didn't get fixed.
It is a really weird issue and I don't think it is because of the routers. Both routers had the same issue and both routers were running 802.11ac (which I think is only the wireless part of the router but yet I know nothing about routers and network setups)
From what I learned so far from trying to fix the problem is. That it is not from the ISP side and the problem is between my PC and Router.
I checked everywhere on the internet and tried to find a solution but I couldn't there is absolutely no information about this problem anywhere.
I will provide any information you require from my side and try to work as much as I can with you to fix this problem. You guys here at Tom's are probably my last hope...
OS: Windows 10 pro
Intro:
