Hello!
So, recently I moved my router into my bedroom from the living room so I could game on my PC through a wired connection. It seems that ever since then, my wireless mouse (Logitech G702) wireless headset (HyperX Cloud Flight) and Xbox One Controller (using the wireless adapter for PC) all disconnect pretty consistently. I figured it had to do with the router itself (Netgear Nighthawk Model R7000) because once I moved it across the room from my PC the disconnects seem to be less frequent. My headset will get static interference randomly. I even tried a new headset (Steel Series Arctis 7's) and they too got some static interference randomly so I do not believe it is the headset. I had to stop using a wireless mouse because of the random disconnects. I think it may be the router because that is the only real change made to my setup. Any help in trouble shooting this would be greatly appreciated. Having a wireless setup is so convenient (also expensive) and I can't use any of it now as it just gets disconnected. So I have wasted money just sitting in the closet. 🙁
Thank you!
Thank you!
