I have been experiencing this issue for the past couple months now. I have the following setup:
-Ziggo ISP in the Netherlands, which is a 500/50 Mbps connection.
-ISP modem/router connected through ethernet with another ISP provided router set up as access point in the floor above. 2 wired connections from the access point to computers.
The wired internet has been functioning perfectely with no issues, but the wireless internet does have an issue where the internet will simply stop working until I turn the wifi in my phones/tablets off and on again. The signal strength is excellent throughout the entire house. Speedtests also give excellent results.
I have already tried the following:
I don't know what else there is to do or what my issue even is exactly. So hopefully the tom's hardward forum can help me figure this out
- Only used the wireless signal of the ISP modem/router at ground floor, disabling the other
- Only used the wireless signal of the ISP access point at the first floor, disabling the other
- Changed the channel various times between 1,6,11 depending on neighbourhood channel saturation
- Changed the bandwidth to 20, 40 and 20/40 mhz
- Only used the 2.4ghz connection since I don't have line of sight of the routers
- Tested the devices while having line of sight
- Increased the DHCP lease time to 24 hours
- Turned off the modem firewall
- Changed the DNS settings on several devices to google instead of the default from the ISP
- Set fixed IP adresses for devices and the access point
- Changed the 802.11bgn between various options
