G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware,microsoft.public.mshardware.product (More info?)
Every half hour or so, I get informed that I should change the batteries
in my mouse (Wireless IntelliMouse Explorer 2.0) as they are low.
However, the batteries are brand new, and the Mouse Control Panel shows
Battery Status - "Wireless mouse battery level: Good". I'm using the
latest IntelliMouse software. I didn't have this problem running under
Windows Server 2003 with the same IntelliMouse software, on the exact
same PC.
Ideas please? This is very annoying when I'm using the PC, and also when
not as it switches the monitor on out of power save mode, and won't let
it switch off again until I dismiss the warning.
Regards,
Alex.
Alex Meaden
Technical Support Officer
Computing Service
University of Kent
same PC.
Regards,
Alex.
Alex Meaden
Computing Service
University of Kent
