We have a Lg. home - over 10,000sqft built in a "U" shape. The center area is a courtyard with swimming pool etc. At the rear of the property is a guest house. All the DSL wiring for internet, phone, gates, and Coax for sat. etc comes into the house to a small room at one front corner. I am struggling to get a consistent, strong wireless signal inside the guest house - as well as the part of the main house farthest away from the control room.
I have tried adding a high gain (15dBi) outdoor antenna mounted to the top of the house, and a repeater with an indoor window mounted high gain antenna. The signal is STILL shaky at best and frequently drops altogether.
Can anyone suggest a better way to put this system together? The location of the router is not ideal, but there isn't a better place for it. Some of the signal issues I think, are due to the thickness & materials of the walls. Even a desktop with a good wireless card installed only picks up 2 bars consistently at approx 25ft from the router. I'm using a dual band wireless N router from DLink.
I am open to any suggestion - regardless of cost. Of course, I would prefer not to spend thousands, but function is vitally important.
Thanks for any help you can provide!
B
B
