Wooden case for PC. Should I?
G
Guest
Guest
Archived from groups: alt.comp.hardware.homebuilt (More info?)
I'm building a computer (very vanilla) and wanted to know if building a
wooden computer case is a good idea or a fire hazard. I've seen some
examples of wooden cases, but I don't know...it just doesn't seem
natural to build one out of wood. I've thought that perhaps putting
metal plates inside the case could make it much safer.
Any thoughts? Should I be concerned? My main reason for building one is
aesthetics AND primarily because I want a slim pc case. I can't stand
these bulky , metal, geeky cases. I would like to build one at the
dimension of 15"(width)x2.5"(height)x10"(deep). I've seen micro-ATX
motherboards and cases, but I'm finding out that they may go
obsolete(low demand I guess). I like the AOPEN h340g, but I need TWO
5.25 bays.
So back to wooden cases. Good or bad? suggestions about anything I
mentioned?
-Jer
I realize there may be some compromises (particularly the power
supply), though now that I'm getting this feedback I didn't realize
about the other hazards.
The power supply is a problem, but the drives, motherboard, risers(for
additional cards and low profile), and others can be doeable. Besides
a power supply...a hard drive is about an inch high. So I'd say 2
inches high would be generous for air to get in and out. But may I
remind everyone that I'm not looking at creating a fancy wooden box or
gaming computer. Its just a simply little computer for browsing the net
and running average applications.
But the more I think about this the more I'm thinking of looking some
more to find a manufactured case instead. If I can find that h340g
case, but could accept a regular ATX motherboard. I guess I can live
with that.
-jer
The FCC may have something to say about your wooden case. Computers tend to
generate RF signals that they would broadcast if it were not for the
shielding provided by their metal cases. You may interfere with your
neighbors' cordless phones, etc.
DaveW
<rjerry@myway.com> wrote in message
news:1125004157.756714.135050@f14g2000cwb.googlegroups.com...
> 5.25 bays.
> mentioned?
> -Jer
A fire isn't likely but it wouldn't meet U.L. safety.
Also, wood is not an EMI shield.
Good luck on making wood walls and braces thinner than stamped metal.
> I can't stand
A homebuilt case will be just as 'obsolete' as any other.
> 5.25 bays.
You need to try making a layout of the things you want to put in it and see
just how hard it is to cram that many devices in a 'slim' case.
> mentioned?
> -Jer
<sigh>
there's always something, now the FCC is pouting. After they built the
typewriter....it should've stopped there. damn those Eniac engineers!!
> 5.25 bays.
> mentioned?
> -Jer
I've seen it done a few times in different styles although trying for
that low a profile is going to force you into some design compromises.
If I were doing it I'd take the time to adhere some thick metal foil
(probably copper) to the inside of the wood for RF shielding and a bit
of heat protection. If you really want to get serious about downsizing
without compromising too much and you have the technical chops you might
like Commell's new board which is fast and super-compact.
http://www.commell.com.tw/News/News/News_20050422_LV-673.htm
This board has IDE support for 2 optical drives, SATA for your hard
drives, dual gigabit lan, USB 2, video and audio with relatively high
performance, and the list goes on and on. It supports 16x PCIe if you
want a high-performance video gaming card too. All that in a MB that
measures 170mm X 170mm (6.7" square)
John McGaw
[Knoxville, TN, USA]
http://johnmcgaw.com
No, it's not good because it costs more and takes a long
time. But, if you want one anyway and like the result then
THAT is good.
> or a fire hazard
Computers don't generally catch on fire, but if it did, yes
that's a fire hazzard... it's your call.
>I've seen some
Maybe just putting some veneer on a metal case?
>5.25 bays.
>mentioned?
How did you plan on cooling it? You can't make a case no
larger, with significantly thicker panels, then stuff yet
another drive into it. IMO, it's highly advisable to make
it at least thick enough to allow an 80mm diameter fan(s),
as it creates a _LOT_ of noise trying to cool modern parts
with sub-80mm fans.
You'd also be doing a lot of work towards a case with very
little potential unless you're looking at using a custom
power supply, as even a mATX supply itself is about 2.5"
thick, ignoring that it then has to rely on a tiny pusher
fan on the rear and that it'd leave you 0" thick panels
above or below the PSU.
H340G is about 3 3/4" tall and you've already noted only one
drive bay, BUT if you did without the floppy drive and
modified that rack a little to improve airflow through the
area you might be able to fit a 2nd drive in it, though for
optimal results you'd probably ned to increase the air
intake on the front bezel some too... that case was
engineered back when systems (including HDDs) didn't produce
as much heat as today.
You could of course put veneer on it, but I suspect that
when all is said and done, you'd have spent a lot of time on
a system that is too limiting because it requires use of
relatively low heat parts. IMO, you should consider making
it bigger... make a nice endtable or filecabinet with the
system built into the base of it.
>5.25 bays.
>mentioned?
>-Jer
http://forum.ozcasemodz.com/viewtopic.php?t=310
Some zany modder and pix of his wooden homemade case
-T-
>5.25 bays.
>mentioned?
I built one years ago round an old 486.
By far the simplest method is to use an existing case and simply strip
the outer panels off. These are then replaced with wood.
In my case ( 'scuse pun ) I used varnished ply - and each wooden panel
was lined with a sheet of copper foil.
I can't see how you're going to meet your 'slim' criteria though,
wood's just plain too bulky a material.
I would say that the only advantage in using wood is the aesthetic one
- and in order to meet that ( and not have the machine end up looking
like a plumber's toolbox ) you have to spend a great deal of time on
the finish.
Another factor to bear in mind is the heat. There's a minimal fire
risk ( I've had valve amps built with wooden cases..and none of them
ever erupted into flames..and they got significantly hotter than a
computer ), but the big problem is warpage. This effectively limits
you to using good quality ply for the case, which will withstand the
thermal variances better than solid wood.
All in all I'd say that wooden computer cases are perhaps best suited
to those situations where looks are more important than size or
functionality - and even then you might be better off just buying a
decent cabinet to stash your machine in.
Regards,
Stephen Howard - Woodwind repairs & period restorations
www.shwoodwind.co.uk
Emails to: showard{whoisat}shwoodwind{dot}co{dot}uk
Then focus on it first, there is no point in getting rest
spec'd one way then finding you had to redesign it all.
2" high internal cavity would work (or should that be
"woodwork"), providing you don't stack the drives, leaving
1/2" unobstructed area above and below. With two drives,
there is no way to make that work AND have the 15 x 10"
dimensions you wanted.
Pick the system components you want to use, acquire them,
then lay them out. You can then find the minimal internal
dimensions possible for this case.
>But may I
>with that.
Why regular ATX? There is no reason to believe mATX is
going away sooner than full ATX.. in fact mATX is very very
common right now, as most of the lower-cost OEM boxes are
using them.
In article <1125004157.756714.135050@f14g2000cwb.googlegroups.com>,
says...
> 5.25 bays.
> mentioned?
THere's a company making alot of money selling wooden cases, mice and
keyboards.
Do it.
Conor
The child is grown, the dream is gone.
I have become comfortably numb. - Pink Floyd
I have one at home I built about 6 months ago. It is constructed out of
half inch mahagony - if that catches fire something was seriously wrong
in the first place. It is also about 7 inches high - I wanted something
that looked like a 1940's wireless set. Works fine but for a 2 1/2 inch
enclosure wood wouldn't be the first material of choice. As others have
indicated, maybe veneer is a better bet. I remember a product called
'microwood' from a few years ago that was almost paper-thin wood veneer
with a self stick backing. That would probably be your best bet for
this.
Andrew Smallshaw
andrews@sdf.lonestar.org
> in the first place.
Of course. But the point to safety standards is to prevent something
'seriously wrong' from turning into a serious disaster. I.e. A burnt
computer is one level of 'serious' but a burnt house is quite another.
Having said that, the odds of (thick solid) wood catching fire from a
computer failure is pretty low because the high power components are
supposed to be current limited.
> this.
DaveW writes:
I haven't noticed any interference from modern PCs, even with the case
open, and even with other devices held right next to the case.
Transpose mxsmanic and gmail to reach me by e-mail.
David Maynard writes:
Just treat the wood to make it fire-resistant. And use an Intel
processor so that it doesn't melt if the fan fails.
Mxsmanic wrote:
> DaveW writes:
You may not but it can and does happen, although I'd be suspicious about
claims it affected the neighbors.
That would help but it would probably be easier to use a metal liner and
that solves the EMI situation as well.
> And use an Intel
What about a molten northbridge, or any of the other myriad components?
ok. I've thought about it some more and this is my current design.
I will use wood only as asthetics, but the main material of the
computer will be out of aluminum sheets(not sure how thick). That is
what a computer case is typically made out of, correct? The wood, if
desired, will be added on top of the aluminum material. My only problem
is that "I've never done this before", well...with aluminum that is.
Great learning experience, but *could* be a b--- to pull off. But
simplicity is the key here. My main question is:
1.> HOW do I weld aluminum together? I've thought of either using a
torch or maybe better yet that mixing compound that you usually find at
auto part stores. But I don't know how strong that stuff will be. I
mean if I drop this casing will it break? My experience with those
compounds is that they do not hold up well when it comes to two metals
twisting against each other. I know what ya'll are thinking..."DON'T
TWIST THE CASE!". But seeing how little torque I applied to the two
metals...makes me wonder how good of a adhesion there will be for a
casing. Perhaps you know of a good compound or would torching work
better?
And to give you an idea of my casing design, just imagine square sheets
of aluminum...welded together to form a box. I know...revolutionary!
2.> anybody know of a place where I can buy affordable riser cards?
Some of the risers are pretty pricey!
3.> if I put a monitor over this case, will thick aluminum be enough to
hold it up? Or should I put a beams underneath to spread out the
pressure from the monitor?
I hope these are the only issues that I need to alert myself to. I want
this project to be very simple. I've been taking my pretty time here
about how I want to build this computer and what I want for a computer.
And now I have the image of the custom case, in my head, and I've made
the design so utterly simple. But now I need to know about the 3
concerns that mentioned above. comments?
you guys have been very helpful with all your posts. I didn't think I
would get this much feedback. thanks a bunch.
-jer
better?
-jer
In article <1125206405.032575.322910@g49g2000cwa.googlegroups.com>,
says...
> better?
1) Buy a cheap ass case instead of using ally. Drill out the rivets and
keep the motherboard tray,the HDD/floppy drive cage and cut out the
section that the expansion cards go into.
2) Because you've cut out the expansion card section, this won't be an
issue.
3) Use beams. THey don't need to be very thick.
Conor
kony writes:
> Perhaps, but did GPUs of that era do so?
GPUs of that era didn't require fans, and so they would not overheat.
I believe many current GPUs have thermal shutdown, especially those
with fans.
> I'm not trying to discount
> the usefulness of a thermal shutdow, but rather putting it
> in perspective that plenty of people do have systems of that
> era or older that continue to run fine without a CPU thermal
> shutdown feature.
If the CPU doesn't require a fan, or if the system is mostly idle most
of the time, they may get away with it indefinitely.
> The AMD CPU died from failure of another subsystem. Would
> any CPU survive from a signifant failure of the voltage
> regulation subsystem? Usually yes because of the typical
> nature of such failures, but still they have no protection
> from it. The focus should always be on the failure point
> before the CPU and you've made no mention at all of any fans
> to avoid.
The AMD CPU didn't come with a fan. The Intel processors do.
On Mon, 29 Aug 2005 04:07:54 +0200, Mxsmanic
<mxsmanic@gmail.com> wrote:
>kony writes:
Yes, there were common video cards in the earlier Athlon era
that used fans... not all, but not all now, either.
>with fans.
>> shutdown feature.
>> to avoid.
Both manufacturers sold retail and oem (bare) product. Buy
an OEM Intel CPU and you don't get a fan either- same diff.
In article <11h4gie7mnshca@corp.supernews.com>, David Maynard says...
> I'm not thinking of fan failure and other 'normal' failures as those are
> catered for. It's the 'unexpected' kind that make for unforeseen problems.
In that case, all computers are in the same boat.
Conor
"You're not married, you haven't got a girlfriend and you've never seen
Star Trek? Good Lord!" - Patrick Stewart, Extras.
In article <njt3h1hvg5q3mpbfeiq8n21c738fq0fhou@4ax.com>, Mxsmanic
says...
> I agree. But having some sort of protection in the CPU is an extra
> layer of security. All fans fail eventually, and I assume the MTBF of
> a CPU is greater than even that of the best fans (?).
However it has been proven in the P4 that if you run an app that has a
high CPU utilisation such as some 3D games, the CPU will throttle
itself when it gets hot and bring the system to a crawl.
Conor
In article <8cr4h1le923bs5p8nuc7lgi66rqmac0kqj@4ax.com>, Mxsmanic
says...
ROFLMAO. 6502 and Z80 CPUS didn't need fans or heatsinks and they
regularly overheated in arcade machines.
So do AMD Retail.
Conor
