Workgroup vs Domain sharing problem
G
Guest
Guest
Archived from groups: microsoft.public.windows.networking.wireless (More info?)
I use XP Pro sp2 at both home (tower) and work (laptop).
My home system uses a workgroup and my laptop is a member of a domain. Both
have the same name. Lanca
I also have a netgear wireless router to share internet access.
I am trying to share my home printer - which is shared, but the laptop will
not recognize the tower in order to add the shared printer. I also on
occasion wish to share files. The laptop takes a very long time even showing
me the lanca network location when trying to find it at home.
The tower recognizes the laptop, and if I double click on it, it asks for a
user name and password, then gives me access to the laptop.
What am I doing wrong??
Thanks,
Malke
3,000
> Both have the same name. Lanca
> will not recognize the tower in order to add the shared printer. I
> also on occasion wish to share files. The laptop takes a very long
> time even showing me the lanca network location when trying to find it
> at home. The tower recognizes the laptop, and if I double click on it,
> it asks for a user name and password, then gives me access to the
> laptop. What am I doing wrong??
> Thanks,
Here is how to use your laptop (domain account) at home:
from MVP Lanwench:
Note - you don't need to change to a workgroup just to access resources
on it. You shouldn't play with your laptop's network settings at all.
Once you've logged in using your domain account (using cached
credentials), and have an IP address on the home network, you can map
drives, use printers, whatnot, very easily - one way, in a command
line:
net use x: \\computername\sharename /user:computername\username <enter>
Malke
MS MVP - Windows Shell/User
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic!"
G
Guest
Guest
> > Thanks,
> from MVP Lanwench:
> line:
> Malke
> "Don't Panic!"
I'm not sure I typed in all the right variables, so if you could be a bit
more specific, it would be helpful.
Home tower computer has a name of P4
Home user is golfnutz
Laptop name is lsd-vaiolaptop
Laptop user is golferd
not sure what to put in for sharename or user
Thanks,
Golfnutz
Malke
3,000
>> from MVP Lanwench:
>> resources on it. You shouldn't play with your laptop's network
>> settings at all. Once you've logged in using your domain account
>> (using cached credentials), and have an IP address on the home
>> network, you can map drives, use printers, whatnot, very easily - one
>> way, in a command line:
>> <enter>
> bit more specific, it would be helpful.
Here's a link to an MS article which details the full use of the net use
command:
http://tinyurl.com/3bpnj
Malke
"Don't Panic!"
G
Guest
Guest
"Malke" wrote:
> >> from MVP Lanwench:
> >> <enter>
> command:
> Malke
> "Don't Panic!"
Using the net use command only shows me my disconnected work network drives.
It will not show me my home workgroup or P4 computer, so I still cannot
connect to the printer or access the shared drives on my home system.
Could the wireless router be stopping things? It doesn't make sense since as
I said earlier, P4's view workgroup computers sees the laptop and can access
it's resources if I set them to share. It just asks for a valid user name and
password.
Why would it only work in one direction??? My home computer (P4) has all
it's resources shared.
Thanks again,
Golfnutz
Malke
3,000
Golfnutz wrote:
> "Malke" wrote:
>> >> from MVP Lanwench:
>> >> one way, in a command line:
>> >> <enter>
>> > a bit more specific, it would be helpful.
>> use command:
>> Malke
>> "Don't Panic!"
> drives. It will not show me my home workgroup or P4 computer, so I
> still cannot connect to the printer or access the shared drives on my
> home system. Could the wireless router be stopping things? It doesn't
> make sense since as I said earlier, P4's view workgroup computers sees
> the laptop and can access it's resources if I set them to share. It
> just asks for a valid user name and password.
> all it's resources shared.
> Thanks again,
> Golfnutz
No, the wireless router is not stopping things. It sounds as though you
have a firewall misconfigured. Here is a network troubleshooter by MVP
Hans-Georg Michna. Go through it carefully and it will pinpoint the
source of the problem.
http://www.michna.com/kb/wxnet.htm
Malke
"Don't Panic!"
