[SOLVED] Working on a System Build for a Friend
cardinalstar16
18
Hey guys I'm pretty much looking for an opinion on the build I have set up so far for a buddy of mine. I think that the CPU and GPU combo are quite good together but I'm not sure about everything else. The price is right at around $1200-$1300 (although there's probably a $200 wiggle room). I'm also looking to make this build good for as long as possible too, basically I want him to be able to play AAA games at high FPS for as many years as possible. So here's the list along with links to the PPP :
CPU -- AMD Ryzen 5 3600 3.6 GHz 6-Core Processor
https://pcpartpicker.com/product/9nm323/amd-ryzen-5-3600-36-thz-6-core-processor-100-100000031box
CPU Cooler -- Scythe Mugen 5 Rev. B 51.17 CFM CPU Cooler
https://pcpartpicker.com/product/8GBrxr/scythe-mugen-5-rev-b-5117-cfm-cpu-cooler-scmg-5100
Motherboard -- MSI B450 GAMING PRO CARBON AC ATX AM4 Motherboard
https://pcpartpicker.com/product/t7...atx-am4-motherboard-b450-gaming-pro-carbon-ac
Memory -- Corsair Vengeance LPX 16 GB (2 x 8) DDR4-3200 Memory
https://pcpartpicker.com/product/Dk...b-2-x-8gb-ddr4-3200-memory-cmk16gx4m2z3200c16
SSD -- Samsung 970 Evo 500 GB M.2-2280 NVME Solid State Drive
https://pcpartpicker.com/product/P4ZFf7/samsung-970-evo-500gb-m2-2280-solid-state-drive-mz-v7e500bw
HDD -- Seagate Barracuda Compute 2 TB 3.5" 7200RPM Interanal Hard Drive
https://pcpartpicker.com/product/mw...tb-35-7200rpm-internal-hard-drive-st2000dm008
GPU -- NIVIDIA GeForce RTX 2060 Super 8 GB Video Card
https://pcpartpicker.com/product/FY...2060-super-8-gb-video-card-900-1g160-2565-000
Case -- Fractal Design Meshify C ATX Mid Tower Case
https://pcpartpicker.com/product/BB...ite-tg-atx-mid-tower-case-fd-ca-mesh-c-wt-tgc
PSU -- EVGA BQ 600 W 80+ Bronze Certified Semi-modular ATX Power Supply
https://pcpartpicker.com/product/Dm...-semi-modular-atx-power-supply-110-bq-0600-k1
OS - Windows 10 Home OEM 64-Bit
https://pcpartpicker.com/product/wtgPxr/microsoft-os-kw900140
Alrighty, so that's it. I'll also include the full system build link at the bottom. I hope it was easy enough to read. ANY suggestions are welcome. I've build a few PC's but still far from a pro.
https://pcpartpicker.com/list/tHRvvW
More bang for the buck. Didnt include Windows since buying OEM for 100 bucks is a rip off Heres how you cna get Windows 10 OEM keys cheaper https://www.tomshardware.com/reviews/get-windows-10-free-or-cheap,5717.html
PCPartPicker Part List: https://pcpartpicker.com/list/NVYhdm
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($174.99 @ Amazon)
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard ($114.99 @ B&H)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 Memory ($84.99 @ Amazon)
Storage: Crucial P1 1 TB M.2-2280 NVME Solid State Drive ($109.99 @ B&H)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive ($54.98 @ Newegg)
Video Card: EVGA GeForce RTX 2070 SUPER 8 GB GAMING Video...
Video Card: EVGA GeForce RTX 2070 SUPER 8 GB GAMING Video Card ($513.98 @ Newegg)
Case: Fractal Design Meshify C ATX Mid Tower Case ($99.95 @ Walmart)
Power Supply: Corsair TXM Gold 650 W 80+ Gold Certified Semi-modular ATX Power Supply ($108.98 @ Newegg)
Total: $1262.85
Generated by PCPartPicker 2020-04-10 17:36 EDT-0400
That looks good except for the PSU - the EVGA BQ is of questionable quality. The G2 or G3 would be a much better unit. Alternately consider the Corsair RMx or the Seasonic Focus / Prime units, those are typically considered the best. I'd also suggest the Tomahawk Max over the Carbon.
If you wanted to save more on the suggested parts list you could get a 5700 XT like the Sapphire Pulse model and you would get the same performance and save $100 or $120. By suggested list I mean richiestang's suggestion.
