[SOLVED] Worth going from i5 6600k to 8700k (Photoshop/Web Dev, Occasional gaming/premiere pro)
saudor
82
6
18,665
Hey all. Currently running i5 6600k and a RX 580. the i7 is ~$160 USD so it's basically 1/2 the usual price. Unfortunately, i would need a new board. Ryzen is no good since I run a hackintosh and those favor intel CPUs (hence the RX580 since Nvidia = no good)
I use this system for heavier photoshop (tons of layers, PSD sizes are about 300-700 mb) , illustrator, web development, some video editing and occasional gaming.
The games I play run ok for the most part but CPU runs a little high. In detroit become human, it's mostly stuck at 90%+ and can definitely see it bottle necking even with a rx580.
For graphics work, i think the i5 is enough but i don't know any better so maybe im missing out.
Thoughts? Or better to go for something newer
Other details: 4K Freesync display but i run all my games at 1080/1440 and tweak to reach around 45-60fps. 32GB DDR4@2400 RAM, 4GHz mild overclock @ stock voltages on the i5 on a Z170 XP Sli board
Thanks!
Ram helps. With the 11th gen cpus, you can take advantage of higher speed ram, same as with the K class cpus on a Z mobo.
Also 11th gen run 20pcie lanes, so m.2 in at least 1 slot is cpu direct, not run through the chipset, and pcie4.0 capable, which can work well with larger files used with Photoshop.
I don't see the move to an 8700k as being that much of an overall benefit over the 6600k, you'll spend $500+ to add 6 threads, with very little IPC gains.
11400 not only keeps up with a 9700k, but beats it. Results may vary depending on ram/OC.
And that's not mentioning the power and cooling requirements differences between a 11400 and 8700k which = noise.
i5-11400 would probably be better than an older i7. Not much more expensive. 10400F is also an option. at $154
8700k - 6 cores 12 threads, max boost 4.7Ghz
i5-10400F - 6 cores 12 threads, max boost 4.3Ghz (but 3 generational improvements in output)
i5-11400 - 6 cores 12 threads, max boost 4.4Ghz (but 4 generational improvements in output)
I5-11500 4.6Ghz max boost
Reactions: saudor
What is your current motherboard?
How much ram do you have?
Photoshop can depend on lots of ram.
Your current motherboard should be able to support a processor as strong as a i7-7700K.
They go for something like $250 used on ebay.
I would not go that route.
For $210, you can buy a i5-11400 which is considerably stronger and any lga1200 motherboard will do, they start at about $70.
Reactions: saudor
Reactions: saudor
I am currently running 32 GB DDR4 @ 2400 on a Z170 XP SLI board. Bumped it up last year to 32 from 16 since CC2020 was chewing through it as i tend to have multiple files open to re-use assets.
I also do have a mild overclock on my i5 at 4 GHz at stock voltages.
And thanks for the advice everyone! Looks like a resounding no on the 8700 and better to go 11400 if anything (or just stick with the 6600k until hackintosh is no longer relevant and migrate to a ryzen build)
Simple. They ran higher voltages/current and the manufacturing process was far less efficient in comparison.
Oh, BTW, the 10850k can pull almost 270w without issue. Age has little to do with that, it's a matter of additional cores, additional threads, Lcache, memory controller etc all adding up. The 10850k is not much more than a refined and tweaked 6600k, same architecture, just a lot more under the hood.
And doesn't do so well on a budget board simply because of VRM limitations.
pic_disp.php
As you can see, the 11600k basically beats out the 10900k, so thats going to put the 11400 and 10850k in the same general vacinity, the 11600k only having a slight edge over the 11400 because of clock speeds. For the money and requirements, the 11400 is far better value here than the 10850k. Compared to a 6600k, you'd be looking at closer to double the ability.
