Would a CPU upgrade help?
SlimRed
8
Hello all.
I am a streamer and was curious if a CPU upgrade is needed to increase my experience.
I have an i7 4770k @ 3.5 GHz (3 years old), a brand new 1060 SC 6 GB card and 16 RAM. My internet and OBS settings are fine.
When I stream I get only decent FPS, even when I'm playing at low gfx settings. Would a CPU upgrade help this issue pretty significantly?
Its the only thing I can think of that is causing the low performance when streaming considering it's 3 years old and perhaps not as up to date with newer games.
If so, what would be a good CPU upgrade?
Thanks.
tanckattb
Commendable
Jan 31, 2017
126
47
Have you tried overclocking? I think you would get better fps (even if it's just a few) if you try overclocking it. If you really don't wanna overclock, well, DEAL WITH IT.
kidding haha
It really isn't a good idea to upgrade (it's only 3 years old). Maybe wait a year or two more.
If you wanna upgrade NOW, get a ryzen processor. It has incredible Multi threaded capabilities, and its number of cores will do good for streaming AND gaming at the same time.
What game do you play btw I wanna see your stream xD
SlimRed
8
Thanks for the response. I'm more of a variety streamer atm, just started.
https://www.twitch.tv/slim__red
SlimRed
8
A SC 1060 card is more than capable of streaming games at high quality with good fps, let alone low quality.
SlimRed
8
Do you know of any Intel cards that would suffice? More knowledgeable on them.
A Core i7 6800K would work if you must have intel.
SlimRed
8
I'll look into them both. Appreciate it
