I have an AMD a8-7600 APU with a gpu that cannot do dual graphics. Would it be better to buy an AMD R7 240 - 250 to do dual graphics or would buying a GTX 750 just be a better purchase?
Single cards will draw less power for a single display - depending upon the games you are playing, and the resolution/FPS you want to run, a single card will probably work as well in most applications. What is your budget for the GPU?
Around 120$ is the highest I want to go. So should I just go with the GTX 750?
I use the NVidia 750ti - it does ok on the gaming - it runs 4 displays without issues. To get a true performance based gaming card - your budget would need to be closer to $300+.
im not looking to run new games at max settings most new games my current card can get decent fps at 720p.
Whats the best GPU I could get without bottle necking the APU
