Joshua_155 :
EpIckFa1LJoN :
Joshua_155 :
I just loaded up WoW for the first time in ages. I have a GTX 1080 and have this issue. I was able to fix it with one setting change. I changed from Full Screen to Borderless Window (Fullscreen) mode. I was only able to achieve 55 fps even at quality 1 until I did that. Now I lock at my refresh rate of 85hz (using Gsync and VSync) with Max Quality, MSAA x8 and a resolution of 3440x1440. If I turn off Vsync I sit at about 100fps.
I also run Windowed (Borderless) I just forgot to update this. That is a well known problem with WoW and is not exclusive to 10 series cards.
What zone and server did you do this testing in?
And what are your system specs?
Those play HUGE factors.
With my settings at 1440p I still can't break 45 fps in Stormwind on Stormrage which is arguably the most active alliance WoW server.
But I can also get 200+ fps with vsync off in EN during fights.
But I hover around 60-70 in Suramar.
Zone and server play huge roles since the more players aroundthe more work the GPU has to do.
The zone I tested in initially was Feralas with nobody around. Couldn'the break 60fps at 3440x1440. I switched to full screen window and my frame rate doubled. No reason I should have been in the 50s in Feralas with nobody around.
I7-4790k
32 GB
GTX 1080
That's my point though. When you do get into more populated zones your fps is going to drop like a bomb, especially if you are on a highly populated server. When I am in Suramar and I turn AA up I drop to 30 almost immediately, and it stays there. I also use vsync because the game tears horribly without it, you have a very high end monitor I am assuming since you have Gsync and UWQHD, so the gsync would help as well.
