Wraith Spire RGB issues
Relatyvity
12
I'm losing hope with this, I know it's pretty amateur, but I can't figure out what the problem is.
- AMD Ryzen 7 1700
- Asus TUF B350 Plus Gaming
- Wraith Spire
According to the mobo's manual, everything should be connected properly, but I don't know how to configure the Spire. As of right now, the only color it's willing to light up in, is red. Asus Aura is unable to detect it, so I can't tell if I've actually plugged the RGB header into the mobo right, but one would think that otherwise it wouldn't light up at all.
Is there any ways to test it? I have also seen that Aura is kind of picky when it comes to which version you are using, which is great, because at the official page, it doesn't recommend any versions, just the A.I. Suite which has control over the fan RPM but not the colour...
Please help! I either sleep or leave my rig running for the night, the damn thing is too bright 😀
afaik, BOX Wraith Spire cooler follows motherboard's RGB color
(since it light up, then the RGB cable is plugged in right position)
if you don't want it to light up, just unplug the cable
