I think I got an issue with my X1950XT & chassi configuration. I haven't found anything about these cards being especially hot so im showing you guys some pictures to see if I got my chassi-setup wrong.
Idle the cards gets up to 55-57c and under load approximately 75-80c. I find that to much. No other card I used got this high ever. Opening the chassi-side helps some; down to 51c, still to high I think.
Got a 120mm fan directly below the PSU for better airflow also.
Here is image 1 and image 2 (800x600, aprox 100kb/each).
1) I might be to jumpy so I gotto ask; IS 75-80 to high under load? And 55-57 idle?
2) Can I do something with my chassi so the air flows better?
[EDIT] Found this in another post here;
Could this be something?
Well first of all, It takes time for the thermal paste to react. your temps should be high for a few days then it will go down. Just make sure u have good contact with the Cooler and GPU.
