Question X570 I AORUS PRO WIFI no video display
Jul 23, 2019
I'm setting up a new build with with the X570 I AORUS PRO WIFI and AMD Ryzen 5 3600, I do not have a GPU installed right now.
After getting everything wired and i try booting the computer for the first time and get no display. I have rechecked the CPU power and Bios compatibility everything looks good, but there is an update out that i was gonna try and Q-flash with out a CPU.
Are there any good guild on how to Q-flash with out the CPU?
Is there anything else I should check?
You probably having issues like i did and need an HDMI plugged in. I had several issues regarding my new build which ended in the result of RMAing back to Newegg for replacement. It is my belief they've really messed up on some bios cause my m.2 would suddenly vanish within the bios and not even post past the Windows circle loader or leave me with a black screen....
Thanks!!! with the aditional GPU conected to monitor is working.
A final question, ¿ is normal that motherboard´s hdmi conectors dont work ? ¿What would I do for get video signal with MOTHERBOARD´S HDMI conectors?
