chuckshissle
Splendid
Use this aftermarket cooler. Very effective and cools graphics card really well, makes a big difference compare to stock cooling. It's silent and vents out heat back and out of the case so it helps reduce the temperature inside the case as well. Replacing the thermal compound with Artic Silver 5 also helps lower the temps a bit.
I have used Artic Cooling Silencers before and Im very impressed.
Make sure you have enough space to use this aftermarket cooler.
http://www.arctic-cooling.com/vga2.php?idx=61
