Xeon cpu temperature 59-62 while desktop and 90 degrees while gaming: Cooling comes from i5 cpu
csandreas1
314
I have recently upgraded my cpu to a xeon x3470. The cpu was a used one from Aliexpress and came with a thermal paste. I applied the thermal paste with an amount of a pea in the middle of the cpu. When im in desktop use, the cpu is between 59-66. The temperature is not stable, it depends on the programs i open.
When gaming the temperature can go up to 90 Degrees celcius depending on how stressed is the cpu on each game.
Some gameplay of my cpu can be found on these two links:
https://www.youtube.com/watch?v=T0IYvCb0NBA&t=4s
https://www.youtube.com/watch?v=XFWih0PYXT0
I am not sure if it is a cpu problem or if it is just a bad thermal paste.
Note that the cooler i am using is the one that came with my pc from dell inspiron 580 with the old i5 650.
my system specs can be found here:http://www.userbenchmark.com/UserRun/4809510
My power supply is 300 watts.
You need a TDP that is significantly higher than the TDP of the CPU, else it will stabilise at a high temp.
Anything that is compatible with socket 1156 will fit.
https://www.quietpc.com/lga1156-coolers
"The sockets are mechanically identical so if a cooler will fit LGA1150 then it will also fit LGA1151, LGA1150, LGA1155 and LGA1156, or vice-versa."
You've been given lots and lots of advice that you need a bigger and better cooler and lists of ones that will fit.
You seem to keep coming back to 'will this do' or 'it won't fit' with no evidence as to why it won't.
You have an 1156 socket, any...
okay i will buy this one, thanks. But why you say that the Cooler Master Hyper 103 CPU Air Cooler is good for 40-60 watts TDP only? Where did you see that the hyper 103 is not good enough? i want to know for the future sorry for too much questions :)
Is there a solution to this? I mean can i patent the panel somehow to make some space for the cooler ? I is like 0.5 cm taller
Hii ,
I have same computer Dell Inspiron 580s ( with new case, transferred all components from old slim chassis to big one ) .
I bought the same cpu x3470 from Aliexpress like you. My cpu temprature while gaming is around 70-80C.
May I know what Cpu cooler are you using now ?
I am using the ARCTIC Freezer i32. It is great cooler my temperature while gaming do not exist 60 C. You may need to replace the fan though, because our motherboard makes a problem for the stock one.
