I used to have AT&T. They always had slowdowns and whatever and it was annoying the hell out of me so I decided to switch. By the way, my whole house was wired for Cat6 ethernet, since it is fairly new. So tech comes, installs the new internet. It works great, fast speed. So then I go to start my PC up to test it out there, and to my surprise, no internet. My ethernet cable wasn't picking up a darn thing. I was confused. I checked the wall ethernet port, all was good. So then I went to the networking box in my walk in closet. It looked quite different from when it was before. It seems that the tech snipped the wire that goes into the panel with all the ethernet cables to all the rooms, and directly wired the broadband to the service. Basically disconnected my whole home ethernet system from the service. I legit had no idea why he did that, but he did. It was a pretty crappy job too, I could probably tear that connection apart without any effort.
TL;DR: lazy tech disconnected my houses ethernet wiring from the service, what are my steps to fix this?
(edit: added image)
Yellow is the current cable that's being used. Green is the ethernet panel which has been entirely cut off. Red is the shoddy connection between the two. Right side of the yellow is the side that goes to the modem, left side is the side that goes to the ISP.
(edit: added image)
