Question XFX 6750xt help
wargasimxd
4
need a little help with my xfx merc 6750xt. just upgraded from a old gtx 980 Ti i bought back in 2015. problem im having im getting the same fps in warzone 2 and bf 2042 as i did with the 980Ti. Ive used every video settings in game from low to recommended and getting the same frames as i did before. most of the time my 980Ti got better frames. I know there is a issue but cant figure it out. using the amd adrenaline software and using there OC settings made no difference. in COD warzone 2 with the 980ti i was average 90 on low and high and ultra around 60-70. With the 6750xt on ultra average is 60-70 and low settings 70-80, so the 7 year old card is out performing it and cant figure out why
Which processor/CPU do you actually have ? Maybe the CPU is holding back the new AMD GPU ? Kindly provide full PC specs as well, including the PSU model.
Complete system specs should ALWAYS be accompanied with any driver, hardware, or performance question. Do not post DXDiag reports as they contain a TON of useless information. Posting a DxDiag in place of a System Spec List tends to ward off potential members from helping you.
Please supply the following system details/information. No need to provide each and every detail though, only relevant to your issue at hand. This is just for reference:
(Complete System Specs)
-CPU make and model# (clock speed/voltage, type of cooler, and "Core" temperature @ idle and load)
-Motherboard make & model# (include Bios version if graphics card is not recognized or you are having stability issues)
-RAM (amount, clock speed, model#/link of kit, configuration)
-Graphics card(s) make and model# (clock speed, voltage if modified, Driver version and GPU temp both @ idle and load)
-Power supply make,model#, "AND" age (note if using 110V or 220V A/C input)
-HDD/SSD configuration (ie: Raid setup/ back up/ OS drive/etc..)
-Case/Chasis make,model# (fan make, model#, and configuration if having thermal issues)
-Operating System (If using Windows note Framework and service pack version)
-Monitor make, model#, and resolution (If model# is unknown list resolution and refresh rate)
*If the unit is a "laptop" or "All-in-one" system you must note the make and model# of the unit. Be sure you are ALWAYS using the OEM/manufacturer's Driver updates for the unit.
*If "Crashing":
-Note the nature of the "crash" in detail, as there are several definitions for the word "crash".
*If "performance" related issue:
-Note the "exact" point in which the performance reduction occurred (ie: After Windows update, After Bios update, After Driver update, After thermal system shutdown, After Hardware change/upgrade etc...)
*For diagnostic purposes please disable the following:
-Any/all Antivirus/ Anti-malware software
-Any/all OSD monitoring software
-ALL overclocks outside of factory spec
Yup, as guessed before, your current CPU is indeed creating a bottleneck with your new GPU. Time for an upgrade, if you want to maximize the 6750XT's performance. I always increase the screen resolution as a temp solution while gaming if my processor is holding back the GPU.
Increasing resolution can at least put some more stress/load on the GPU, rather than CPU. Sometimes doing this helps, but not always.
dam means i have to upgrade my dang mother board too, it oonly supports 6th gen intels. how to you increase the screen res? my monitor is a asus tuf monitor 164hz 1920x1080 thats the only res i can see
