XP Home and HP 932c printer
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
Printer will print a correct test page, but nothing else.
Uninstalled/reinstalled to no avail.
Did you uninstall and reinstall correctly?
http://www.coribright.com/Windows/Article%20One.htm
Cari
MS-MVP Windows Technologies - Printing/Imaging/Hardware
www.coribright.com
"coachb" <anonymous@discussions.microsoft.com> wrote in message
news:1decc01c4549d$7d219cd0$a501280a@phx.gbl...
make sure your are using the correct printer port for your printer. xp has a
long list of ports available. make sure you check the one that is listed
next to your printer. good luck i had the same problem...this solved it.
