XP not saving Network Key after it being typed in.
Marshintire
Guest
Nov 23, 2012
11
Hello, I am on a Gateway 600 YGR (?) Laptop running Microsoft XP and I am having trouble making a wireless network remember the Network Key after it was typed in and told to "connect to the network." How do I make the computer remember the network key? It keeps refreshing to a six digit network key when I had typed in a thirteen digit one.
Marshintire
Guest
Nov 23, 2012
11
I have tried using the Window's Wireless Internet Connection interface as well as the Broadcom Wireless Utility-- neither has been able to successfully connect to the internet, which was why I had assumed it might be the problem. Otherwise another possibility is that a Network was set up at some point, would that interfere with it?
Marshintire
Guest
Nov 23, 2012
11
No error messages occur. Though when I try the "repair connection" function the error messages that come up through there are "unable to connect to wireless network" or "cannot renew IP address."
Marshintire
Guest
Nov 23, 2012
11
To be thorough, four other devices have successfully hooked up to this particular internet connection with the Network key I have been trying. So I assume it has to do with the settings on the computer and not the Wireless Network itself.
Switch to the Windows Wireless Connection Wizard then set up a connection (or at least try). Then open a command session and type "ipconfig /all" (without the quotes) and hit <return>. Capture and post the output from that command.
It's also entirely possible that your adapter doesn't support the encryption level in use on the access point (low on the list but still possible)
Marshintire
Guest
Nov 23, 2012
11
I'm paranoid about what information is good to have online or not so I took out the physical address, which I'm assuming isn't all that important.
It's not needed here but the MAC (Physical) address doesn't need to be hidden.
I do need one additional piece of information. Does your access point transmit the SSID or is it hidden? If hidden then unhide and try again. XP has always had problems with hidden SSID (besides the fact that hiding it doesn't do a thing for security)
Marshintire
Guest
Nov 23, 2012
11
It is WPA-Personal (PSK). The computer kept thinking it was an ad hoc network for a while but I changed it to WPA ( which is what it is trying to recognize it as now ). There is another laptop connected to it that has it as WPA and it is connected and can view web-pages.
