xp media center 2005 with rollup 2 does have remote desktop connection available, i have it on mine, i remote to it every day, it's supported, looking at my computer properties right now as i type this
Remote desktop is available, but I don't believe the icon is there in some OEM versions for some reason. I have a gateway in which it was absent.
http://www.microsoft.com/windowsxp/mediacenter/evaluation/faq.mspx
MCE has everything Pro has and more, if yours doesn't show it, try a different user profile with administrative rights to see if it shows up
Not true, why does everyone say that? We've already established that Windows XP Professional features, specifically Domain Join and Cached Credentials (Credentials Manager for logons) are not included. As a result, you will be prompted for your logon user name and password to access network resources after you reboot or log back on to the PC. In addition, file shares or network resources that are set to require a domain-joined PC for access will not be available. Furthermore, it is non-upgradable and non-downgradable for that matter in order to make the media center non-transferable. Something to consider before installing it no matter how good it is, because when something better does come out you'll be forced to wipe and reinstall.
I also don't like that the Media center software has the capabilities to sell you products from Microsoft affiliates, or that even something as seemingly innocent as my viewing habits can snooped and sold to these same affiliates.
To quote Wierd Al...."I watched Will and Grace One time, one day, and now my TIVO thinks I'm gay."
I just think if you only have one computer, why would you turn it into a glorified TIVO box when it could be used for so much more. If you have more then one machine, why would you sacrifice the ability to securely network them.
I copied the system32 directory, inf, help, etc. and then ran the FAST wizard. Installed XP Pro and restored to my new machine. You have to use the FAST msi from the backup, but it works. Now I can do everything I need to do and I let my DVR run my TV.
