I got Windows XP and during the install (during the initial blue screen after you boot from CD.) It stops at random times saying it can not copy the file or the image is bad. If I restart the computer, it may stop at a totally different place. And sometimes it works without any problem at all.
And this is all after a clean NTFS format.
Then during the main install after it rebooted, the computer either hangs, blue-screens, or weird error messages appear. And it all appears at completely different times. And they all say a different error message every single time I restart the computer.
I've checked the Microsoft HCL site and all my hardware is compatible with XP. So I know that isn't a problem.
I have been told that it is very possible that one or more of my RAM modules is bad. Is that a possibility? Because my 2k OS was starting to become unstable before I upgraded to XP. The system used to be very stable, and I've made no changes to the hardware. So I am led to believe it is a hardware issue and something has gone bad.
Could it be the CD-Rom drive as well? I havn't had any problem with it before.
Any ideas? Thanks.<P ID="edit"><FONT SIZE=-1><EM>Edited by jerry292 on 04/08/02 11:14 PM.</EM></FONT></P>
