XP Setup Problem
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
I recently formatted my sons harddrive which had XP on it previously.When I
try to reinstall I get a message that certain files cannot be copied.I have
tried this over and over again with the same results.I have done everything
that the knowledge base says even flashed the bios.I built the system it was
running fine accept for the spyware and popups.Can someone please
help.Thanks in advance.
Rich
Probably because you formatted ahead of time. That's unnecessary with XP as
you can format during XP setup which is where the procedure should be done.
I don't know what procedure for installation you are using but the following
are the proper steps:
Assuming your system is set to boot from the CD-ROM drive, boot with the XP
CD in the drive. If it isn't or you are not sure, you need to enter the
system's BIOS. When you boot the system, the first screen usually has
instructions that if you wish to enter setup press a specific key, when you
see that, do so. Then you will have to navigate to the boot sequence, if
the CD-ROM drive is not first line, set it first in the boot sequence. Save
your settings and exit with the XP CD in the drive. The system will reboot.
A few screens into the boot process, if you see the message on the boot
screen to "Press any key in order to boot from the CD," do so.
After loading drivers and files, you should be taken to a screen with
the following:
To Setup Windows XP now, press ENTER.
To Repair a Windows XP Installation using Recovery Console press R.
To Quit setup without installing Windows XP, press F3.
In your case, press ENTER.
Agree to the License agreement by pressing F8.
You will then be taken to a screen with two options.
To repair the selected Windows XP installation press R.
To continue installing a fresh copy of Windows XP without repairing,
press ESC.
This will bring you to a partition map where you
can delete, create and format partitions.
Select the drive you wish to format, delete the partition, then create a new
partition, format as desired and continue with XP installation.
Michael Solomon MS-MVP
Windows Shell/User
Backup is a PC User's Best Friend
DTS-L.Org: http://www.dts-l.org/
"Richard Balaban" <rbalaban@optonline.net> wrote in message
news:FbOdd.35608$YM4.11783633@news4.srv.hcvlny.cv.net...
>I
> have
> everything
> was
> Rich
Richard, you could try copying the contents of the WinXP CD to the hard
drive and do the install from there.
From the WinXP CD choose the New Install Advanced Option. It should
give you the choice. Also while there you can
delete and create a new partition and reformat.
>I
> have
> everything
> was
> Rich
