4 4sdf Honorable Jul 21, 2012 14 0 10,510 Jul 22, 2012 #1 Is that cooler compatible with Ati HD6850 ?
Solution nikorr Jul 22, 2012 Turbo 2 is newer : ) And supports the latest cards. So, if u are planing to upgrade and use this, get this one. Accelero Twin Turbo PRO http://www.arctic.ac/en/p/cooling/discontinued-products/vga/22/accelero-twin-turbo-pro.html Accelero Twin Turbo II http://www.arctic.ac/en/p/cooling/vga/375/accelero-twin-turbo-ii.html?c=2182
nikorr Champion Oct 22, 2009 23,335 0 54,960 Jul 22, 2012 #2 Nope. http://www.zalman.com/eng/product/Product_Read.asp?idx=276 Upvote 0 Downvote
nikorr Champion Oct 22, 2009 23,335 0 54,960 Jul 22, 2012 #3 Get this one instead. http://www.newegg.com/Product/Product.aspx?Item=N82E16835186046 Upvote 0 Downvote
nikorr Champion Oct 22, 2009 23,335 0 54,960 Jul 22, 2012 #4 Check the review http://vr-zone.com/articles/arctic-cooling-announces-standalone-accelero-twin-turbo-pro/8049.html Upvote 0 Downvote
4 4sdf Honorable Jul 21, 2012 14 0 10,510 Jul 22, 2012 #5 Sounds pretty good. Could you tell me what is the difference with this http://www.newegg.com/Product/Product.aspx?Item=N82E16835186052 ? Which is better? Thank you for your response! Upvote 0 Downvote
nikorr Champion Oct 22, 2009 23,335 0 54,960 Jul 22, 2012 #6 It just have added compatibility to more cards, has 1 more heat pipe, uses more power. Uses 4 pin vs 3 pin. Upvote 0 Downvote
nikorr Champion Oct 22, 2009 23,335 0 54,960 Jul 22, 2012 Solution #7 Turbo 2 is newer : ) And supports the latest cards. So, if u are planing to upgrade and use this, get this one. Accelero Twin Turbo PRO http://www.arctic.ac/en/p/cooling/discontinued-products/vga/22/accelero-twin-turbo-pro.html Accelero Twin Turbo II http://www.arctic.ac/en/p/cooling/vga/375/accelero-twin-turbo-ii.html?c=2182 Upvote 0 Downvote Solution
nikorr Champion Oct 22, 2009 23,335 0 54,960 Jul 22, 2012 #8 Other than that, they are almost the same in performance. Upvote 0 Downvote
4 4sdf Honorable Jul 21, 2012 14 0 10,510 Jul 22, 2012 #9 I think i go for the twin turbo II. Thank you so much 😀 Upvote 0 Downvote
4 4sdf Honorable Jul 21, 2012 14 0 10,510 Jul 22, 2012 #10 Best answer selected by 4sdf. Upvote 0 Downvote
nikorr Champion Oct 22, 2009 23,335 0 54,960 Jul 22, 2012 #12 This topic has been closed by Nikorr Upvote 0 Downvote
