C C_Boog Reputable Sep 22, 2015 6 0 4,510 Feb 21, 2019 #1 Hi- I just upgraded my CPU and Mobo, but now I’m gettting the blue screen of death and this message when I boot in Windows 10: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED Any advice? I thought this upgrade would be a lot easier than I thought.
Solution kanewolf Feb 21, 2019 A motherboard change usually requires a clean Windows OS install. If you didn't do that, then that is probably the reason for your problem.
kanewolf Titan Moderator May 29, 2013 38,573 3,784 156,790 Feb 21, 2019 Solution #2 A motherboard change usually requires a clean Windows OS install. If you didn't do that, then that is probably the reason for your problem. Upvote 0 Downvote Solution
