1066mhz kingmax or 800mhz Kingstone/Corsair
Mike666
7
Hi Guys!
Which one is better?
DDR2 Kingmax 1066mhz 2x1GB
DDR2 Kingstone 800mhz 2x1GB
Price is same and i dont know how much the brandname counts.
the CPU would be E6750
both of them are CL5
i found a third competitor:)
Geil 2048MB 800MHz Black Dragon Dual /2x1024MB Kit
this is the same price as well and its CL4
In either case you should check the QVL compatible memory on the manufacturers website and try to get RAM that is on the list. Understand that the 2G packs have additional numbers and letters on the model number. Here is the Gigabyte list motherboard_memory_ga-p31-ds3l_1.0.pdf . I'm using Crucial Ballistix 2GB DDR2 800 on a P35-DQ6 and it works flawlessly.
Well, Kingmax is 1066 on default, with 1.8V (I believe) - that looks promising. Others could probaly be OC-ed to that speed, but would need more voltage.
But in the end, I don't think it makes much difference.
